Re: 966 power steering
Posted by M.Genrich on January 07, 2014 at 19:27:44 from (166.182.3.162):
In Reply to: 966 power steering posted by craig reavley on January 07, 2014 at 10:48:04:
On the bottom of the mcv near the center you will find an o-ring style plug that screws in from the bottom up. Put a bucket under the mcv and take the plug out. Under the plug is the steering relief valve, reach up in the hole with a needle nose or I use a flat jawed snap ring pliers and pull the valve out. Start the tractor and run it until oil is running out, this primes the mcv pump. put the valve and plug back in and you should have steering and brakes. If oil doesn't come out like water out of a garden hose you may have a week mcv pump, dirty filter, or something.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
