Re: Did I destory something in my 986
Posted by mkirsch on January 08, 2014 at 05:27:00 from (65.199.189.6):
In Reply to: Did I destory something in my 986 posted by NEKS on January 07, 2014 at 19:03:13:
The growl could also be the fan blades cavitating due to the radiator being plugged with snow, for example.
Did it go away? If so, don't worry about it.
Did the tractor run and drive once you got it warmed up? If so, don't worry about it. Hydraulic oil doesn't pump well at that temperature, and it takes forever to warm up just sitting there idling. A pump might be getting a little weak, but that's just a guess.
With tractors like this you almost have no other choice but to run it until it breaks down, so the problem can be found and fixed. You could spend thousands replacing things "preventatively" and still not fix an intermittent problem like you describe.
You didn't destroy anything with what you did. If anything is broken, it's from decades of wear and tear, not one cold start.
