Re: cub
Posted by Jim in Ma. on January 09, 2014 at 05:34:23 from (72.70.100.67):
In Reply to: cub posted by ken house on January 08, 2014 at 18:35:52:
First thing I would do if it will turn over is a compression check. You have the crank. If it tests real low pull the head. Pay close attention to the valve seats. If they are pitted badly you will need another block. In the worst case you have a lot of parts to sell. Good luck
  • Re: cub Jim in Ma. 09:59:05 01/09/14 (0)
  • Re: cub John M 08:06:49 01/09/14 (0)
  • Re: cub teddy52food 07:11:04 01/09/14 (1)
    • Re: cub David G 07:55:33 01/09/14 (0)
