Re: Farmall M front transmission seal leak!
Posted by wayne in mn on January 09, 2014 at 08:54:06 from (64.118.12.118):
In Reply to: Farmall M front transmission seal leak! posted by Jim R on January 09, 2014 at 07:08:24:
Hardest job is to loosen the driveshaft bolts. They are tapered and hard to loosen. This is how I have "easily" loosened them: 1. Turn shaft(clutch depressed or rotate engine) so bolt is on the bottom, 2. Take a combination wrench and place box end on the bolt head, 3. Remove nut & lock washer with second wrench or socket, 4. Take a larger combination wrench and lock the box end into the open jaw of the first wrench so you have (in effect) a longer wrench. ( this will test the lifetime warranty of the tool!), 5. Place transmission in 1st or reverse (clutch pedal released so engine resists turning) and lock the brakes. 6. Apply firm pressure to turn the tapered bolt; when it "snaps" the bolt can be removed.
You may need a pipe wrench to help hold the shaft &/or coupler from turning. Remove the two bolts on the shaft first and the coupler bolts last.
Heat or hammers, etc. may do the job but simply turning the bolt works so much easier & faster.
