Re: Many tractors
Posted by caterpillar guy on January 09, 2014 at 16:51:05 from (68.188.235.54):
In Reply to: Many tractors posted by Janicholson on January 08, 2014 at 08:56:51:
I like the western slopes better than the eastern slope. I guess that is because Denver is on the eastern slope.
Delta I was over in the Cortez area a few years ago. What a view there. Nice valley through there. Was also since then through from I-70 over to Grand Junction. Then across US-50 over to 114 to Saquache, and down the gun barrel to Monte Vista. Then back up through there. All in the winter.With an air seeder 12 feet wide. I had to wait for them to open the passes. The first trip I went out over La Veta pass. The trip around the Reservoir on snow pack al the way. Came back the next day was all clear to the pavement.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
