Re: 12v coil
Posted by F-Dean on January 10, 2014 at 07:49:41 from (70.209.13.251):
In Reply to: 12v coil posted by sparky70 on January 10, 2014 at 07:38:46:
As I understand it, you have 2 choices:
1. Run a 6-volt coil with the ballast resistor
2. Run a 12-volt coil with an internal resistor without a ballast resistor
But no ballast resistor with a 12-volt coil that has an internal resistor.
If this is not correct, I am sure I will be corrected - it won't be the first time I have been wrong!
