Posted by John T on January 10, 2014 at 09:20:40 from (71.0.66.0):
In Reply to: 12v coil posted by sparky70 on January 10, 2014 at 07:38:46:
One converted to 12 volts, the choices are:
1) Keep the old 6 volt coil and use an external series voltage dropping (12 to 6) ballast resistor.
2) Use a full true 12 volt coil (some call internally ballasted, although there's actually NOT any discrete stand alone resistor hidden away inside lol)
One advantage of a 6 volt coil plus an external ballast, however, is the ability to use a start ballast by pass circuit, so when cranking the coil sees un ballasted battery voltage for potential improved starting especially if its cold.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
