Posted by SDE on January 10, 2014 at 15:50:24 from (174.124.30.237):
In Reply to: Farmall C points posted by Noah in IA on January 09, 2014 at 17:47:59:
I replaced the points on my 400 about three weeks ago or less. I removed the distributor cap and then rotated the engine until the rotor was pointed to where the #1 terminal would have been, had the cap been on the distributor. I then checked the alignment of the timing mark on the pulley to the pointer. I took the distributor off the tractor and took it into the house. I was careful to not rotate the shaft, but that would not matter as long as it were returned to the #1 position before installing it. After installing the new points I put it back on the tractor and it started right up. Easy to do. SDE
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
