Farmall H rear axel diameter
Posted by Jon Wescott on January 10, 2014 at 21:10:46 from (107.223.146.225):
Anyone know if the rear axel diameter on a Farmall H and on a Farmall 460 is the same and is the keyway the same. I would like to know if the cast iron hubs will interchange. Thanks
