Re: hard to start when its cold
Posted by John G. Hasler on January 11, 2014 at 17:40:22 from (174.124.78.227):
In Reply to: hard to start when its cold posted by Roy Prins on January 11, 2014 at 17:06:29:
1) Check the point gap. Should be .020".
2) Check the timing (0 at 375, 20 at high idle)
3) If you have a 12V coil make sure you have no ballast resistor.
4) Check the plugs.
5) Make sure the choke is closing all the way.
