Re: 300 heavy FH points?
Posted by Dean Olson on January 11, 2014 at 19:42:38 from (107.129.21.153):
In Reply to: 300 heavy FH points? posted by Lucid on January 11, 2014 at 12:28:47:
third party image
third party image
My Super C's have the small points and my 300 has the large. I had
a 240 with small points back in the day.
It's easy to use small point implements on a large point fast hitch
with spacers. This is practical for most implements. While my 300
would certainly pull my 2-14" C20 plow it would be hard to get the
wheels spaced correctly.
My 7' disc designed for the super c works great behind the 300, 2nd
pic. This is overkill because that disc works equally as well behind
the Super C. My blade designed for the SC works far better on the
300 due to the down pressure and a much heavier tractor.
1st picture shows my 300 pulling an 8' spring tooth cultivator
designed for my SC. I had to run a couple miles over to buddies
place and the road gear in the 300 was nice.
You could cut down large points to use on small point fast hitch but
I can't think of very many practical applications. I wouldn't cut
down my 3-14" plow or 8' disc harrow to work on my Super C.
