As has already been said, begin with the basics. Make sure that the points, condenser, plugs, plug wires, coil, battery, and all associated wiring is in good order. Set the timing correctly. Then, make sure the carb. is operating correctly, clean and not plugged, fuel not stale, and there is adequate fuel. If the engine is in good condition, and all of the above items are correct, it should start and run well.
One must remember: these are very simple engines, ignition, and fuel systems, and were design for easy starting. You can say that it was an imperative. These old tractors were designed to be as easy and trouble free to operate as possible, hence their simple construction.
To illustrate the previous, I own the first truck I ever drove, a 1949 Ford F-2. This truck is all original, complete with a flathead V-8. Although the body is rough, mechanically I have alway been meticulous in maintaining it. The engine was last gone through some 23 years ago. In 2012 I decided to resurrect the truck after it had sat for 13 years. Knowing I did not want any hassles with starting or reliability, I very carefully went through the fuel, wiring, and ignition systems. The result is a truck that I drive back and forth to work everyday (which isn't far, 3.1 miles, don't want to wear it out). This past week, we experienced lows in the evening of around -16. On the coldest day, I had to employ a heat gun directed at the battery to get it to start, but it ran flawlessly. It also still sports a 6 volt system.
The point is, make sure that the ignition first, then the fuel system are at factory spec. and condition, and the old girl will run and start fine.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
