Re: international 484 diesel, fuel control problem
Posted by 495man on January 12, 2014 at 06:32:31 from (24.137.107.69):
In Reply to: international 484 diesel, fuel control problem posted by JimB2 on January 12, 2014 at 06:20:09:
Exactly, put throttle lever in low idle position, put open ended wrench on large nut on end of shaft through removed right hand side cowl panel. Pull throttle lever to high idle position, should tight nut enough, repeat if necessary.
