Re: Loader Q's (JD 45) for H
Posted by John W. on December 14, 2000 at 11:28:25 from (216.228.202.237):
In Reply to: Loader Q's (JD 45) for H posted by Patrick on December 14, 2000 at 10:57:55:
Patrick, it shouldn't be very hard to fabricate some side extensions--or just build a bigger bucket. The trick might be to find someone close enough to you to do the measuring and fitting. If I remember right that #45 loader is rated for up to 1800 lbs. so you might keep that in mind. I have a #45 on a JD G. It's a good loader but I would like to add a bucket tilt cylinder someday. If you happen to have a digital camera I'd like to see how your loader mounts to the rear axle.
Post A Followup
: Re: Re: Loader Q's (JD 45) for H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
