Posted by Janicholson on January 12, 2014 at 12:02:09 from (74.60.94.18):
In Reply to: 184 light problem posted by bv on January 12, 2014 at 07:11:09:
Smoke is not good. Pull the cover off the area to get at the switch and wires. There is a resistor on the switch that dims the lights when the switch is in D position. If the resistor is OK, it still gets way hot enough to burn off accumulated trash, dust, dirt. If it appears that the resistor is smoking let it do so. The only caution is if you wired up extra lights, or put different bulbs in the pans. The resistor and switch are designed for about 70 watts or so, and cannot be used with higher output than stock lamps, or more of them. A relay is needed to make extra lights work, or a separate switch for them alone. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
