Posted by gbs on January 12, 2014 at 13:36:05 from (71.51.252.209):
i removed the top link bracket to see how much piston seal leakage it had,as suspected the piston is seal leaking ,question is there are 3 more small streams of fluid coming from the right rear of the cylinder are these normal,if not i will try to locate their source,also does the lift use the same pump as the remotes
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
