well first of all, there is no farmall in the 15-30 tractor. it is called 15-30 mccormick deering. as you refer to this 15-30 as a 1929 model then it is the updated version called the 22-36. the 15-30 gear drive tractor came out in 1921, after the titan models. in 1929 the 15-30 had a bore increase of 1/4" to 4 3/4" bore. this gave it 425 cu.in.from the 15-30's 382 cu.in. a water pump and oil filter was also added to the 22-36, along with larger radiator cores. the serial # tag showed it as the 15-30 model but the h.p. ratings showd 22-36 instead of 15-30. the 22-36 was built till 1934 and replaced by the wa40. the farmall model is a totally different tractor which was originally the farmall regular which the farmall models originated from in the early 1920's all the standard tractors used the name mccormick deering till around 1949 then they used mccormick only in the decals. then when the w-400 came out in 1954, replacing the super w6 ta, the international name was used and no more mccormick.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
