Re: dt414 to 466 swap / 856 power steering
Posted by MikeinKy on January 12, 2014 at 16:52:42 from (184.45.97.149):
In Reply to: Re: dt414 to 466 swap / 856 power steering posted by caseyc on January 11, 2014 at 21:28:21:
I did a similar switch, just on a smaller scale. The engine went bad in my 766 and I put in a DT414 out of a combine. I still pull the same stuff I always used it for, it just does it easier. It made it a lot better tractor.
