Re: spark plug wires to distributor location
Posted by rustred on January 13, 2014 at 07:20:25 from (74.214.152.80):
In Reply to: spark plug wires to distributor location posted by Charles Myers on January 12, 2014 at 18:28:34:
the plug wires are in the same position on all of these old tractors since 1939 with distributers. # 1 wire is always at 2 oclock ,then 4 oclock, 8 oclock and 10 oclock following the firing order. on the diesel models the rotation is opposite but still starts at 2 oclock. also the little screw for points on side of distributer should sit at 3 oclock when timing is properly set. this is proper position from factory.
