I've been doing some research on carports. A local guy sells the carolina carports brand. I've been through their online configuration utility and they have carports that are tested to withstand some pretty impressive winds and snow loads. IIRC they have a model rated for 150MPH winds, and 50lb/ft snow loads.
From what I've seen you want one that has the ribs on the roofing running parallel to the gable end, not parallel to the peak. They shed water and snow much better. They can be had with any number of walls and doors.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
