Re: Toubleshooting help - battery won't stay charged
Posted by mkirsch on January 13, 2014 at 12:02:46 from (65.199.189.6):
In Reply to: Toubleshooting help - battery won't stay charged posted by SuperCDon on January 13, 2014 at 09:41:45:
1-wire alternators are a hit-or-miss proposition on discharging.
Some will discharge the battery while sitting, some won't.
With a 3-wire setup and a proper diode, you are 100% guaranteed that the alternator won't discharge your battery.
The diode is EASY, all you need to do is go to radio shack and buy the biggest diode they have in the electronics drawers. They come in packs of two.
Back at the tractor, cut the wire running to the #1 terminal on the alternator somewhere convenient, and strip the ends. You don't have to solder the diode. Use wire nuts and tape if you want. Connect the diode with the end that has the line pointed toward the alternator.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
