With a very tight press fit. Very tight. You need a bearing splitter, and a piece of 3/8 plate steel, and a ten to twenty ton hydraulic jack. Check the picture in the link. To see more pictures click on "Project Journals" in the left hand margin of the page, then click on "Farmall C Trike, SouNdguy.
To put the pulley back on, you use a piece of 1/2" all-thread, a good 1/2" nut, a small plate of steel with a hole, and an 2" pipe coupling. At least that's what I use.
I have seen some pulleys with a bolt in the center of the crank, and I have seen some with set screws, but most are press fit. Good luck with it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
