Re: Crankshaft pulley on Farmall A
Posted by gene bender on January 13, 2014 at 18:13:47 from (207.177.56.213):
In Reply to: Crankshaft pulley on Farmall A posted by Farmall A Tractor on January 13, 2014 at 14:53:28:
Never know what has been changed does it have a set screw but all are pressed on and some are very hard to pull. You can use a split bearing puller thingy and a three jaw puller DO NOT PULL ON THE PULLEY or it will break thats why you use the bearing puller behind the pulley.
