Re: 1066 engine problems
Posted by ihcowner on January 15, 2014 at 17:15:15 from (166.182.3.22):
In Reply to: 1066 engine problems posted by Deere4960 on January 15, 2014 at 09:05:49:
Pull the pan and see where the coolent is coming from. If it is the orings, you might be able to just replace them. Have done that on a couple of 400 series engines worked great. Take the sleeve and piston out together, that way if it is good you don't have to rering it.
