Posted by gene bender on January 15, 2014 at 18:48:04 from (207.177.56.213):
In Reply to: super a gear box posted by farmall4856 on January 15, 2014 at 15:23:10:
I have done several. Easy way is to remove the axle and wheels. Then you can remove the bottom half of the steering sector. You also want to remove the steering wheel and then the large nut on the steering sector ,screw the steering shaft out thru that hole. To remove the bottom half of the sector the drag link will need to slide off the main shaft as you drop the bottom. Then you can replace seals,bushings and bearings and gaskets. Fill with 90-150 when done and it will work like new again.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
