Re: 706 steering have ICE in it?
Posted by The tractor vet on January 15, 2014 at 20:21:22 from (75.19.125.103):
In Reply to: Re: 706 steering have ICE in it? posted by 4010wy on January 15, 2014 at 20:14:52:
Surch the archives as i have coverd tis over and over again . The dump valve is located on the back side of the MCV valve body and that is located on the center section of the tractor on the left and has linkage to the clutch pedal . Set down and read how to do this and you will be fine . Now as to Bl3eeding out the steering lines ya had best plan on getting new o/rings as if you try and POWER bleed the system more then likely you will blow out the O/Rings . (0% of your problem is contaminated oil and a plugged filter . Always keep several filters and gskt. on hand and change the hyd. filter several times a year.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
