Re: A clutch question
Posted by FBH44 on January 16, 2014 at 03:24:23 from (64.85.216.125):
In Reply to: A clutch question posted by notjustair on January 15, 2014 at 19:05:37:
Adjusting the clutch is one thing, but on my "H" tractor I also had to re-adjust the pressure plate fingers. You might check for that. There is an IHClutch Adjustment Manual, you can get in on eBay, the way I read it it specifiecs for an A it can be externally adjusted, to a gap of 1/2" between the fingers and the plate.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
