Hydraulic Valve SMTA
Posted by Dan on December 14, 2000 at 22:16:58 from (12.18.161.164):
I have a SMTA with a live pump and remote hydraulic valve in addition to the "lift all" valve. IN the operator's manuel (old bood with parts gone) it appears that to use the lift all you have to put the remote valve in the foreward position and fasten it there. IN that case you couldn't use both at the same time. From the plumbing on it it would appear that hydraulic oil would go to both and the pressure would be on whichever valve was opened. Is this correct? I realize the lift all uses single action cylinders only.
Post A Followup
: Re: Hydraulic Valve SMTA
