Re: 2 Farmall H questions
Posted by Zachary Hoyt on January 16, 2014 at 07:40:04 from (74.47.51.121):
In Reply to: 2 Farmall H questions posted by Reinders on January 16, 2014 at 07:32:02:
The brake adjustment to tighten it up is on the actuator, with the heavy spring. You unpin the clevis and turn it in or out as I recall. The water pump should spin freely when there is not a belt on the pulleys, with the belt in place you would be turning over the engine when you push on the fan so it will be stiff. 6 quarts in the liftall. There is supposed to be a dipstick in there but I have only found one out of about 10 Hs I have had.
Zach
