Re: 2 Farmall H questions
Posted by jasinpa on January 16, 2014 at 07:47:30 from (67.234.166.174):
In Reply to: 2 Farmall H questions posted by Reinders on January 16, 2014 at 07:32:02:
make sure you use 30w oil in that hyd. pump , hyd. oil wont work , also the dip stick was only used on the late model tractors like 50 & on , but will work in any years if you can find one , make sure that fill hole has the breather cap on it too, the screw under the brake cover is just to adjust brake so it dont drag the top side of band on drum nothing more
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
