Re: 2 Farmall H questions
Posted by FBH44 on January 16, 2014 at 13:02:11 from (64.85.215.157):
In Reply to: 2 Farmall H questions posted by Reinders on January 16, 2014 at 07:32:02:
Oh yes, those concrete blocks are deadly.
Here" s my notes on adjusting my "H" brake bands.
To Adjust / Tighten Up Brakes;
[To Move Brake Pedals Closer to Transmission Cover; ]
 Un-do bottom locknut on bottom of brake drum housing.
 Then re-adjust bottom square-head bolt up firmly, then down ~ ½ / ~ ¾ turn.
 Tighten the bottom locknut BUT NOT TOO TIGHT, you may rip it out.
 Remove cotter pins.
 Un-do the rear portion of the springs.
 Remove the clevis pins.
 Thread IN the clevis to tighten up the brakes. [1 full turn moves brake pedal ~ 1/8” closer to transmission cover.]
 Reassemble.
 Do each side evenly, so tractor brakes evenly left/fright.
