Posted by Owen Aaland on January 16, 2014 at 17:21:28 from (216.47.34.47):
In Reply to: 1066 engine problems posted by Deere4960 on January 15, 2014 at 09:05:49:
Something to keep in mind about the 400 series engines. The sleeves have three O-rings on them but only the top one does the sealing. The lower two serve to locate the sleeve in the block. If there is erosion in either the block or the sleeve just replacing the O-rings will not result in a satisfactory repair. There are repair sleeves that can be installed in the lower bore of the block to salvage a damaged block. They do require some machine work in the block to be installed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
