Posted by Churchboy on January 17, 2014 at 18:41:15 from (208.103.203.105):
Hey guys having a bit of a timing issue with my 1951 Farmall M. My tractor jumped time one day and I pulled the distributor out finding the drive gear teeth are almost rusted to nothing causing my engine to jump time. The issue I am having is I can't for the life of me find a 12 tooth drive gear online. only ones I can find are the ones with the "R" code and the teeth are straight. Mine look like the go at a angle. Any help would be much appreciated I don't have the money for a new dist even if I did I can't find one of them online with the tooth count, Thank you- Josh
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
