Re: Hitachi alternators
Posted by Gerry Powell on January 18, 2014 at 06:29:23 from (173.172.83.6):
In Reply to: Hitachi alternators posted by Farmall A Tractor on January 16, 2014 at 19:30:09:
The 14255 is slightly larger but I decided to use it since it came with the connector but the 14231 doesn't (OReillys).
Here is a diagram showing the connector layout.
Remember too the current specs for alternators are typically at 3000 rpms, which it can't supply on a tractor running at half that engine speed. At 1800 rpms, the output of an alternator is about 60%, so the Hitacha's could supply 21 and 30 amps. And that could only be into a totally discharged battery or a fault.
The other advantage of the Hitachi is it comes with a split belt pulley which can be adjusted to fit a 3/8 belt, the 10si comes with pulley for a 5/16 belt.
third party image
This post was edited by Gerry Powell at 06:48:02 01/18/14 2 times.
