Posted by Bob M on January 18, 2014 at 09:14:21 from (69.207.86.40):
In Reply to: SMTA troubles still posted by LaDuke Farmall on January 18, 2014 at 08:24:45:
If it still has spark when it dies, problem's gotta be insufficient fuel flow into the carburetor.
Try removing the drain plug from the bottom of the carb bowl. You should be rewarded with a continuous, SOLID stream of gas out the bottom (flow should be sufficient to fill up a coffee can in a minute or two).
However if the just drips or dribbles out, something is restricting flow into the carb bowl.
Look for debris partially blocking the fuel tank outlet, a plugged screen in the sediment bulb, a plugged screen behind the carb fuel inlet nut, something caught in the float valve seat, or the float binding/set too low.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
