Posted by sparky70 on January 18, 2014 at 11:42:52 from (74.118.207.185):
I think I have my Super C steering seal installed correctly in the bearing cage with the widest part of the seal tapered end down to go over the worm wheel shaft (pic 1), but I am kinda stuck on which of the two gaskets go on first. The diagram I have calls for two gaskets and it appears 52952DA is a little thicker than 52951D, otherwise why two gaskets? If it is thicker it is only by a little bit, or maybe different material? I am assuming 52952DA goes between the two bearing cages and 52951D goes on top of the upper most bearing cage. If any of that makes sense I would appreciate confirmation. Thanks. Sorry, could not delete pic of old seal.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
