Re: Farmall h won't start
Posted by El Toro on January 18, 2014 at 12:50:30 from (96.244.7.206):
In Reply to: Re: Farmall h won't start posted by Brady miller on January 17, 2014 at 18:24:47:
Remove No1 sparlplug near the radiator and bring No1 piston to tdc on the compression stroke. Remove cap on mag and see where your rotor is pointing. Should be at the No1 plug tower. If the timing is ok check the magnetism on your magnets inside your mag. Use a flatblade screwdriver. They should attract screwdriver with a lot of effort. They may be 50 to 60 years old. Hal
