Re: Headlight switch wiring
Posted by sony224422 on January 18, 2014 at 13:30:15 from (50.133.160.171):
In Reply to: Headlight switch wiring posted by Jim Becker on January 15, 2014 at 22:03:26:
This is correct. I have the switch figured out. I ended up removing the original resister, and used a 10 ohm 25 watt in its place. I am running a hair over two Amps for leds so it brings them down to about 9.5 volts which looks nice at low power
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
