Posted by El Toro on January 18, 2014 at 16:32:09 from (96.244.7.206):
In Reply to: Farmall h weak spark posted by Brady miller on January 18, 2014 at 15:54:52:
Your coil or the mag's magnets may be getting weak causing the weak spark. I would first check the magnets by touching them with a flat blade screwdriver. They should attract the screwdriver with a good bit of effort. If they have strong magnetism I would replace the coil. Be sure to check your point gap should be .013" also clean the points with some 320 wet or dry until shiny. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
