Re: SMTA troubles still
Posted by Brian Schmidt on January 18, 2014 at 16:47:36 from (69.66.237.150):
In Reply to: Re: SMTA troubles still posted by Icuby on January 18, 2014 at 12:41:38:
I'd second that. Drop the oil bath bowl off and try again.
If that don't help, pull out the drain plug in the bottom of the carb. Install a hose barb and a clear section of hose. Loop it up higher than the top of the carb. Turn the gas back on and observe the fuel level while off and running. This will help determine if fuel is being starved to the engine.
