Re: hyd
Posted by Tractordanp on January 18, 2014 at 17:53:30 from (50.137.83.148):
In Reply to: hyd posted by Andrew Griffin on January 18, 2014 at 13:04:56:
Check your selector for single to double action had a similar problem with my 560 I moved it back and fourth a few times think it may not have been completely in double mode good luck
Dan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
