Re: 1950 H Brake Issue
Posted by Lmack on January 18, 2014 at 18:26:00 from (24.131.50.165):
In Reply to: Re: 1950 H Brake Issue posted by wilsonsk on January 18, 2014 at 17:28:52:
If you do have grease, I would check the rear end/transmission for water. If it has been stored outside water will come in around the gear stick. In the day the use and heat would drive off the water as vapor. Remove the bottom plug and see if you get water. If yes there are historical post on how to deal with cleaning the rear end. Then clean up the breaks and replace the band.
