Humidity in a building is probably higher than outside especially when the weather is warming. So you get lots of condensation on the outer surface of things like castings. Condensation on the inside of say a gearbox depends on how much moisture is in the air inside. There will be some for sure but not as much as in the air outside. Loosen the drain plug around springtime, keeping threads engaged, watch for water dripping out. Retighten the plug.Water will be at the bottom of the oil. Run the tractor AFTER doing this. Dan
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
