Re: cylinder sleeve issue
Posted by Jay Snyder on January 18, 2014 at 19:21:09 from (50.50.88.204):
In Reply to: cylinder sleeve issue posted by ziemerj on January 12, 2014 at 17:03:46:
Using a puller? Or trying to do it without? Heat up the sleeve a little and usually with a "slight" amount of force they slide out. Guessing the retainer is gone out of the block bore but could of got a little rust in it and rusted the sleeve in the block. Good luck.
