Posted by Lynn Kaufmann on January 18, 2014 at 20:31:38 from (76.84.120.214):
I removed the fuel tank and replaced the O-rings on the plugs in the flow valve today. One question, I did not notice when I took the spring and outside cap out that the cap had two slots cut in it. I replaced the cap with the slots lined up with the hydraulic line openings in the valve. I hope this is correct?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
