Re: 1950 H Brake Issue
Posted by FBH44 on January 19, 2014 at 02:45:19 from (64.85.215.91):
In Reply to: 1950 H Brake Issue posted by wilsonsk on January 18, 2014 at 17:05:54:
Here"s how I adjust the bands on my "50 "H";
To Adjust / Tighten Up Brakes;
[To Move Brake Pedals Closer to Transmission Cover; ]
 Un-do bottom locknut on bottom of brake drum housing.
 Then re-adjust bottom square-head bolt up firmly, then down ~ ½ / ~ ¾ turn.
 Tighten the bottom locknut BUT NOT TOO TIGHT, you may rip it out.
 Remove cotter pins.
 Un-do the rear portion of the springs.
 Remove the clevis pins.
 Thread IN the clevis to tighten up the brakes. [1 full turn moves brake pedal ~ 1/8” closer to transmission cover.]
 Reassemble.
 Do each side evenly, so tractor brakes evenly left/fright.
