Re: ih 460 pto
Posted by Janicholson on January 19, 2014 at 07:46:58 from (74.60.94.18):
In Reply to: ih 460 pto posted by K.Barry on January 18, 2014 at 19:37:06:
If you feel comfortable tackling the basics of a small engine rebuild, you should tackle it (with the Blueribbon Service Manual) If not the issue will be to remove the PTO from the tractor and take it to have it repaired. The last thing a service technition needs is a basket of parts he/she didn't take apart. The Hytran must be drained to a level below the PTO, (or the tractor must be aimed down hill at 30 degrees or so to prevent flooding the ground). Then it should be simple to remove (a manual is needed!! for you and/or the technition that does the work. Jim
