Check that you have a good blue/white spark that will jump a 1/4 inch gap at ALL 4 plug wires. Also if your daring enough grab the distributor cap when your trying to start it. If you jump 10 foot doing that you have a cracked cap and that will cause a problem like you have. The 340 I have I had a problem sort of like that this summer. Rotor would turn but I found out it only spun when I looked at it but with the cap and rotor on it would not spin like it should and I found some teeth on the distributor drive gear where bad and it moved when it wanted to and not other times which threw it way out of time
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
