Posted by Janicholson on January 19, 2014 at 11:44:51 from (74.60.94.18):
In Reply to: Re: 300 piston posted by 300jk on January 19, 2014 at 11:22:12:
THe pistons would measure that small if measured at the ring lands. (where the rings are located. To get a good size measurement, it is necessary to measure on the skirt below the rings, looking for a maximum real diameter. Also reasonable is to use long feeler gauge blades with the piston in the hole, (no rings). I use .0015", .002", .0025", .003", and so on up to .0085". More than this might be found in a hotrod but not a tractor. the pull force on the feeler when checking this way is about one pound of force. The thicker the gauge the more force needed as they are flat and the cylinder is circular. It would not be reasonable for the piston to be assembled with .0625+ clearance. It would not operate. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
