Posted by D Slater on January 19, 2014 at 11:51:39 from (184.14.177.12):
In Reply to: Re: 300 piston posted by 300jk on January 19, 2014 at 11:22:12:
Original piston diameter was 3.560 to 3.562. For your sleeve measurement the piston should be 3.622 to 3.623. Think it was in the early sixties that IH stopped getting 3-9/16 pistons and sleeves. Since the bare block bore was the same for a C-169 and C-175 engine IH started using the C-175 ones as replacements for both engines. replacement 3-5/8 pistons have the small piston pin. So if you have a big pin C-169 engine setup now, adapter pin bushings are used in the rods to match the small piston pin.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
